ms 461 woods port race thing
paragonbuilder
11:16 PM
Norwich, CT
I don't think I have any shims but I do have a box of plugs
I’ve doubled up on plug washers to give the extra compression needed to index where I wanted, but It will lift the plug a bit. But if you consider what you took out of the squish band, it may be back approximately where the factory intended.
Stihlbro
11:16 PM
Virginia
This is what I’m seeing. It’s like the mains are colliding the center and working to the exhaust port. Not sure if I can explain it but the secondaries look to merge and go up. The mains seem to collide, maybe at a lower pressure and taking the path of least resistance towards the exhaust. Not sure here.... just an opinion.
tree monkey
10:16 PM
wi
yes
