more jms
T.Roller
7:57 AM
Southeast, TN
FWIW,
Jason was sanding jugs assymetrically on purpose on certain saws. Front to back, for exactly the reason Deets brought up + transfer height. His theory was intriguing and wasn't necessarily that hairbrained. If it had been done on a mill precisely, it may have worked out just fine.
Like most things, it's was the execution of his ideas that was the problem (and the end result).
I think he's just a dope head not caring if he fed up people's stuff.
Moparmyway
Its just a saw
7:57 AM
In a meeting
I'm thinking that youre going to lose stroke if you cant the cylinder ..........
maybe not a huge amount, but if you imagine the bore, piston, and case as straight lines, as you move away from perpendicular, you lose stroke and increase squish as well as chamber size
RI Chevy
7:57 AM
earth
I would rather run a stock saw with just timing advance, muffler mod and base gasket delete with a straight 90* jug verses running a saw that had an angled, Kentucky Windage type angled job jug. Just me.
7:57 AM
Angling the cylinder front to back isn't going to change port timing on one side vs the other. It can increase skirt wear.
Depending on how extreme, it would also send the bottom of the exhaust skirt into the crank lobes
srcarr52
7:57 AM
Iowa City
It's science.
Y'all just don't understand.
There are some engines where the bore center does not intersect the crank axis. Usually the cylinder will be lead towards the power stroke side so the rod angle is less when the gasses are expanding. Unfortunately it creates a larger dwell time at top dead center.
blsnelling
Friend of the Riff Raff
7:57 AM
Franklin, OH
Unless I'm still half asleep... I don't believe that would work. Piston rides in the bore so the base being cut on a forward lean would not effect timing at all. It would simply lower the jug timing wise, half of the distance of the difference between front and back.
Exactly.
+1
RI Chevy
7:57 AM
earth
Probably cause more unwanted vibration and premature wear as well.
jake wells
no longer here
6:57 AM
ky
there is a solution to this problem on the forum. if you would have contacted anyone else for there saw service here you wouldn't have any problem.
RI Chevy
7:57 AM
earth
Jake, hind sight is 20/20. A little too late for that now.
RI Chevy
7:57 AM
earth
Sounded stock. My echo would blow that away. Lol
