more jms
Moparmyway
Its just a saw
9:14 PM
In a meeting
FYI to everyone my other 395 had same markings in same exact spots as this one, so it is normal and probably part of the tooling/casting process.
No way ........ more like probably a result of splitting the case and removing the crank to replace bearings, then re-installing.
Mason, I've got a brand new, untouched 395 ......... how much do you want to bet that mine doesn't have those marks ?
TreeLife
I'm Dominick
9:14 PM
Berkshire County, Massachusetts
Disassemble it and check it out amigo :-)
TreeLife
I'm Dominick
9:14 PM
Not to be a richard, but can one of you fine gentleman circle said mark in the formentioned picture? With little sleep in recent days I'm betting I might be missing what we are looking at.
Also, how can you guys tell the bearings are crap from the video? Not being critical, literally asking. I'm a little hard of hearing, maybe I can hear it with my ear buds in?
Wonkydonkey
Plastic member
2:14 AM
Sussex, UK.
super3
9:14 PM
Indiana
Nope.
I been through a couple dozen of these saws along with a new out of the box yesterday.
That is not an OEM knotch.
9:14 PM
This one was leaning forward a bit, rather than sideways Scott?
Is that Bradleys that Jason did?
That's one way to keep the intake duration down.
:D
FWIW,
Jason was sanding jugs assymetrically on purpose on certain saws. Front to back, for exactly the reason Deets brought up + transfer height. His theory was intriguing and wasn't necessarily that hairbrained. If it had been done on a mill precisely, it may have worked out just fine.
Like most things, it's was the execution of his ideas that was the problem (and the end result).
paragonbuilder
9:14 PM
Norwich, CT
FWIW,
Unless I'm still half asleep... I don't believe that would work. Piston rides in the bore so the base being cut on a forward lean would not effect timing at all. It would simply lower the jug timing wise, half of the distance of the difference between front and back.
9:14 PM
Baffles me a bit too. Never tried myself.
I just know that these motors are a puzzle and very often things don't turn out like one would think.
I agree with you, the piston crown is still perpendicular to the bore. Jason said it made a difference, for what that's worth.
