Mini-mac rehab
Steve
Excellence!
10:46 PM
You will need to cut a bigger slot for the updated fuel line plug. Here is what you have now.
You will need to enlarge it to this
The plug will sit in the housing like this. The fuel line and plug are installed onto the carb before the engine assemblely is reinstalled into the housing.
redline4
I'm huge in Japan
10:46 PM
Rosholt Wisconsin
So your saying I cant just push really hard or hit it with a hammer to make it fit?
Too bad.
Thanks Steve!
redline4
I'm huge in Japan
10:46 PM
Rosholt Wisconsin
While the Post Office is mishandling the parts Steve sent me, I decided to do some more work.
I put the handles back on. Wont go into detail, as I think my dog could figure that out.
Took the 4 screws out of the pan.
Gave it a whack with a rubber hammer and it came right off.
A little bit of funk in there, but not too bad.
redline4
I'm huge in Japan
10:46 PM
Rosholt Wisconsin
I got a package in the mail yesterday. I was secretly hoping it would be something cool, but it was mini mac parts.
Thanks @Steve !
I also had a bit of time to reseal the pan and get the crank seals in.
I opened up the case some for the new fuel line fitting.
Not sure if it's enough or not?
Should the block end of the fitting go into the case, or sit on the case?
I had to remove some from the inside, as there was a bump out that would have caused it to sit crooked.
Old line and new line/tank fitting.
redline4
I'm huge in Japan
10:46 PM
Rosholt Wisconsin
Steve also hooked me up with a new vintage AC spark plug.
It seems I hurt some peoples feelings on Antiques Roadshow due to my crude and vulgar handling of the other one.
And after 24 hours, it hold suction like a Dyson.
I found a random screw to take the place of the one I broke that retains the condenser.
@Steve also tells me these have these plastic tubes that belong in the intake and carb mounting holes.
Mine did not have them and he sent me some.
It's possible that they are nothing but cut off KFC drinking straws and he his currently laughing his azz off, but they do fit..
In my overzealousness to feel the wood scratching power of this pile, I never bothered to check the points gap on disassembly. Which, would have been nice to know as non of the literature I have on this tells me that.
@Steve or @Stump Shot do you know what the points should be gapped at?
I found .018", but I dont trust the source.
redline4
I'm huge in Japan
10:46 PM
Rosholt Wisconsin
In the meantime, I went through the carb, but didnt take any pics.
Washer, bearing, drum and clutch on
Now, I wont know if this presents a problem or not until I put the flywheel on, but if install the KFC straws, there is zero movement allowed to adjust the coil gap.
heimannm
10:46 PM
Dike, Iowa
There is enough adjustment of the coil to set the gap to 0.010". Points should be gapped to 0.018-0.020" at their widest point.
Put the fuel line on the carburetor and be careful when sliding the engine into the housing. The tab fitting must lock into the slot in the housing and as you push the fuel and oil tank in position they engage the fuel line fitting and the rubber nipple for the oil line. Actually a pretty reliable system once you get the hang of it.
Mark
10:46 PM
.018" sounds good off the top of my head.
Steve
Excellence!
10:46 PM
As Mark and Mr. Shot said, .018" on the gap is correct. It seems i forgot to send you my mcculloch factory mini mac timing tool. You would use an analog ohm meter to check continuity over the points. They should break contact at 26° BTDC which is where the tool would line up the coil. You can adjust the ignition timing by the point gap. Wider gap, more advance. Smaller gap, less advance.
@heimannm
Mark, Did i do that timing tool correct? I dont think it went in between the legs like that. I though it hit the leading leg?
Steve
Excellence!
10:46 PM
Yep, got those straws out of my wifes glovebox! :D
Steve
Excellence!
10:46 PM
Thanks @Steve !
You're Welcome. :)
redline4
I'm huge in Japan
10:46 PM
Rosholt Wisconsin
Thanks guys!
Looks like I need to do a bit more grinding for the fuel line.
I will set the points to .018-.020 and see what happens.
With time and luck I will be scratching on some wood with it this weekend.
