mortalitool
aka Nick Stoeckel
- 6:01 AM
- Jan 10, 2016
- Lexington, MN
Kevin you do anything to the intake/plate on the carbatooter?
Might advance the ignition timing a bit more. Started at .020 off the key, then went to .030”. Currently at .035”. Snappier and quicker each time, with no signs of going too far.
So far, I’ve thinned the exhaust bridge and widened/squared up the edges, and raised it 2* to 98.
Lowered the intake floor from 60 to 68*.
Left transfers alone at 120*.
Removed the spark screen and drilled (6) 1/4” holes in the baffle
And advanced the timing about 8*
Behind it is better than still in it![]()
Cleaned it up a little and matched it to the intake flange. Wasn’t muchKevin you do anything to the intake/plate on the carbatooter?
Edit*I was thinking the block.
Yes, drilled (6) 1/4” holes in the spitback guard
Ken Moulewhats your channel
Don't have any. You want XS vids. He's the one with happy spinny tools.Hey Kenny. Fire up some Lightening Performance modded Saws and make us some vids...
Currently having some troubles with the automatic oiler. The manual oiler appears to work after 8 or 10 pumps, but after those cuts without using the manual oiler , the chain was dry
No offense to buckin, I like his content. But about any saw can be quick in softwood with a good chain. Stock 10-10 would be quite slow with a 28” bar in ash, at the opposite end of the spectrum.
The "Pro Mac 10-10" was simply the later version of the 10-10 saws and still a 54 cc model.
Same vintage as the Pro Mac 700 model.
This one was given to me by the boys from the local lumberyard. It was covered with fine sawdust from setting in the same room with the dust collector with a leaky sock. With the long clutch cover and aluminum fuel tanks these saws were heavy compared to the earlier models with the magnesium components.
Mark
Thanks Mark. Good explanation. I had my doubts that 10-10’s could be different from one another. Just that throaty exhaust note threw me a little.The "Pro Mac 10-10" was simply the later version of the 10-10 saws and still a 54 cc model.
Mark
It’s true, but there are always those magic saws, I bet there are a few stock 10-10 that have 170+ compression, I don’t own and 10-10’s but guessing 155 is on the low end of stock compression.I have a sp80 with an sp81 cylinder and and sp81 one has 175psi and the other has 155psi, and have heard of a few with near 200psi stock,Thanks Mark. Good explanation. I had my doubts that 10-10’s could be different from one another. Just that throaty exhaust note threw me a little.
