Mcculloch sp125/101b kart saw build thread
Lee H
8:30 PM
cape cod ma.
Ok here it is, Fella's don't ever ask me to do comp test on one of these efin saws.
What a mofo it was. Saw came out from under me twice and upside down i went
on my arse and back. That hurt.
jacob j.
Only the weird
8:30 PM
Coastal Oregon
I went ahead and did two of my SP saws just now - one is a chrome-bore 125c and the other is a .020" over steel-sleeve saw. The steel sleeve saw got to just over 170 psi on ten pulls.
The chrome-bore saw got to 177-178psi in ten pulls. This was using a Lang Tools tester that I bought from @Guido Salvage. I figured the chrome bore saw would have more snap, as
it's more aggressive in the cut.
With the steel-sleeve motors, one factor is if they've been bored/honed, if the person doing the work scraped the squish band with the boring/honing mechanism.
Lee H
8:30 PM
cape cod ma.
And mine has only made a couple cuts. It still needs to be broke it. Terry Ives told me it
takes some to get the rings to seal. I pull my arse off to get it to where it stopped.
Scott Kelsey
10:30 PM
Wisconsin
Guys, I have a question for you all. I remember reading some info in years past regarding NOT to bore cut with a roller nose. I do not know specifically why because I am not experienced with them, but is it because of the chain/driver gap where the bar transitions to the roller allowing the chain to come off the bar, or?
heimannm
10:30 PM
Dike, Iowa
Others will know more, but my experience with roller nose bars is that it is very easy to get a chip or sawdust in that gap and stop the chain dead. It can happen if you have the bar buried in a log as well.
Mark
sawfun
8:30 PM
Portland Oregon
My understanding is that it is very hard on the tip. I've had rollernose bars buried in big wood and never had an issue bucking, then again, I may be just lucky. I have had a sprocket nose locked up with dust & pitch. Having a longer bar than necessary seemed to help with that for me.
heimannm
10:30 PM
Dike, Iowa
This appeared recently.
It has a few problems.
I am in need of a boost port cover if anyone knows where I can find one, I have gaskets on hand.
I may just try to find enough pieces to put it together and put it in the display as a kart engine representing the 101 models. I have a pair of MC 10's and a MC6 in there already.
Mark
Lee H
8:30 PM
cape cod ma.
Mark
I found a boost port cover Mark. I will get it in the mail tomorrow.
heimannm
10:30 PM
Dike, Iowa
Thanks Lee. I'll post some photos of another McKart/saw project that has come across my bench. This one has lived a hard life.
Mark
heimannm
10:30 PM
Dike, Iowa
This one started out with a 101 engine that suffered catastrophic failure when the wrist pin slid over. I had a MC40 on hand so I put that in instead.
I ran it a few times, had a few problems, and eventually traded it with AWOL. He made it run very well, right up to the point the connecting rod came apart and started the major modifications. He filled in the third port, made an internal transfer and modded the piston to accommodate the changes and patched the crankcase back together. New transfer on the left, exhaust on the right.
Piston mods to take advantage of the new internal transfer.
The crankcase was badly damaged, AWOL had patched it and I took it a step further.
At some point during the major failure, the insert on the PTO side was knocked loose in the crankcase. I made a plate to install over the insert to hold it in place, at the same time I sealed the insert with LocTite 290 to maintain the integrity of the crankcase...for a while anyway.
I will try to get this one back together this week just to hear it run again. I have no delusions of it holding up for long, but I would like to make a few cuts with it before it detonates for good.
By the way, the MC40 has been bored oversize from 2.165 to 2.250 currently...that's about as far as can possibly go...MC75 piston in there now.
Mark
Hinerman
10:30 PM
NE OK
Mark
That thing was fast as s-word, and even louder than it was fast!!!!
qurotro
Cookie Cutter
10:30 PM
Ar
Gentleman, an odd question.
Why does the transfer holes has scratch marks on them?? 3 out of 6 holes on mine has hair-like scratch. Can be felt by pencil tip, along with a polished surface around that area. Does not look like dust ingestion to me.
Bigmac
8:30 PM
Can you post a pic?
