Scott Kelsey
- 2:05 AM
- Jun 10, 2018
- Wisconsin
Guys, for what its worth i just stopped by an industrial bearing supplier this morning. I realize these needles can still be found to an extent, but clearly things are not getting any easier to find. The gentleman found me a supplier that has needles the same diameter as the OEM Mcculloch, even with the tapered end, but they are .120 longer. They are .30 cents a piece. He said you can grind them down and taper the end yourself, buff them and they will run fine. He had a customer do that to a planetary gear with over 400 needles, so he said. Dad was a millwright for almost 50 years and he told me there is nothing wrong with doing that as he has done it for high rpm applications at his old mill. Very interesting.
