- 1:59 AM
- Jan 17, 2016
- cape cod ma.
If i get a chance later i will gage the 797 i just rebuilt
I may have a boost port cover for you Mark. I will look later when i get home.
This appeared recently.
It has a few problems.
I am in need of a boost port cover if anyone knows where I can find one, I have gaskets on hand.
I may just try to find enough pieces to put it together and put it in the display as a kart engine representing the 101 models. I have a pair of MC 10's and a MC6 in there already.
Mark
This one started out with a 101 engine that suffered catastrophic failure when the wrist pin slid over. I had a MC40 on hand so I put that in instead.
I ran it a few times, had a few problems, and eventually traded it with AWOL. He made it run very well, right up to the point the connecting rod came apart and started the major modifications. He filled in the third port, made an internal transfer and modded the piston to accommodate the changes and patched the crankcase back together. New transfer on the left, exhaust on the right.
Piston mods to take advantage of the new internal transfer.
The crankcase was badly damaged, AWOL had patched it and I took it a step further.
At some point during the major failure, the insert on the PTO side was knocked loose in the crankcase. I made a plate to install over the insert to hold it in place, at the same time I sealed the insert with LocTite 290 to maintain the integrity of the crankcase...for a while anyway.
I will try to get this one back together this week just to hear it run again. I have no delusions of it holding up for long, but I would like to make a few cuts with it before it detonates for good.
By the way, the MC40 has been bored oversize from 2.165 to 2.250 currently...that's about as far as can possibly go...MC75 piston in there now.
Mark
Can you post a pic?Gentleman, an odd question.
Why does the transfer holes has scratch marks on them?? 3 out of 6 holes on mine has hair-like scratch. Can be felt by pencil tip, along with a polished surface around that area. Does not look like dust ingestion to me.
