Max Flow Air Filter for MS460?
8:03 PM
They flow a touch more. You might gain 500 rpms unloaded from switching from the HD filters. They last a lot longer between cleanings is why I use them. I have 4 green filters I can switch out if needed. I can usually mill 2 gallons of fuel worth and not have to change filters. The HD 2 has to be tapped out or blown out 2 or 3 times in that much use.
TJ the Chainsaw Mechanic
Old Homelites rule!
5:03 PM
That's one thing I notice alot to. Ones with the stock filters that come into the shop are generally packed...ones with the max flow are generally alot cleaner. Thanks for the reply. :)
MasterMech
8:03 PM
Hudson Valley
1128's are bad about packing the filters. Must be all that air heading down the carb.... Vroom vroom...
Moparmyway
Its just a saw
8:03 PM
In a meeting
Leave the covers off unless it's raining
