wcorey
- 7:05 PM
- Dec 11, 2015
- ma usa
My seat o’ the pants take on it…
It seems the primary set of reeds that lets the strato air in is simply another way of doing more or less the same thing as the cutaway piston timed design.
The charge passes across/through the lower transfers and then down the passages in front the crank case, instead of through the piston passages and around the sides of the cylinder.
The secondary reeds being outgoing from the crank case just loop right back in to the middle of the strato tract at a different time in the cycle, when the piston is on its way down.
So at that point that section of passages have a different function, it’s all air/fuel mix by then and goes up and out the upper transfers instead of across the lowers and down.
One last bit of charge into the combustion chamber and from a rearward direction.
Maybe one last squirt to keep the charge velocity going at a time when the crank case pressure is relatively low near the bottom of the stroke where a more conventional design would be losing it.(and taking advantage of the correspondingly low pressure in the combustion chamber).
Though it's so small it's hard to imagine the velocity maintaining all that way...
I'll probably read this again in the morning and wonder what the hell I was thinking, lol...
