Low speed screw keeps backing out on Walbro carb
GBertolet
8:09 PM
PA
The low speed screw keeps backing out on my Poulan 3700 chainsaw. I have to keep a small screwdriver in my back pocket while cutting, to periodicaly turn it back in. Just backing out a 1/4 turn, will make the saw want to stall out at idle. Other than this issue, the saw runs fine. Are there any tricks to keep the adjustment screw to stay put?
smokey7
8:09 PM
Detroit
I've used loctite vibratite or regular blue.
67L36Driver
7:09 PM
Iffin you don’t find a spring, use the wife’s hot glue gun. [emoji108]
GBertolet
8:09 PM
PA
The screw does have a spring on it.
8:09 PM
It's kind of radical but you can use a sharp prick punch or an awl to dimple a few places around the screw .Don't be beating on it with a 4 pound ball peen though .Lightly .
legdelimber
8:09 PM
N.C.
First thing, Make sure the threads on both the screw and inside the carb body are in good condition, not wallowed or partially stripped.
Then make sure that the spring is in good shape and not bent or mashed.
Then make sure that little washer is nice and flat. Not rough or anything that would damage the O-ring or spring end.
Make sure the O-ring and washer are matched in size and then that they fit the screw and carb body.
Then make sure the washer is between the end of the spring and the O-ring.
Then of course the O-ring is under the washer, against the carb body.
Easy to mix it up when we're in a hurry to get back to the wood.
If the O-ring is mashed out or ragged, it won't help much either.
8:09 PM
Another old trick .Take a small ball bearing ,place it in the hole and tap it to deform the first threads .Now don't thump it like you are forging a horse shoe ,tap .Small hammer .
