- 10:01 AM
- Aug 3, 2024
- Oregon
I've got a 372 that I can't get to tune right curious on ideas. All parts I've replaced are OEM. Which includes carburetor coil metering hose bushing oring on oil pump side piston and a ngk bmr6a gapped at .25 high setting tunes like a dream low side i can back the screw completely out then thread on enough so its not falling out the saw will cold start with screw like that plus i can flip it on its sides or top or do a dump test and it remain idling the same even with screw in to almost 1 turn out. Carburetor walbro rwj4 has been taken apart and cleaned and metering lever is set properly. Any ideas where to go next?
