K&N filters for Stihl models
jmester
3:49 AM
VIRGINIA
Will those OUTERWARE fit the stock hd2 filter. I would assume they do. Would just like to clarify.
redoakneck
3:49 AM
Ohio326
I have had problems with the outer-wears filters trapping saw dust in the filter. Keep an eye on it, sometimes doesn't seem to work way it is supposed to???
jmssaws
Banneded
2:49 AM
I never liked any type of wrap on a filter.
Seems to pack full faster
jmester
3:49 AM
VIRGINIA
I use to stretch the prefilters from the original hd filters over the hd2 filters it worked well but was to restrictive for air flow. The outerware are cheap enough maybe I will give one a try. May a least help to keep the filter a little cleaner from the big chips that get stuck in there.
jmester
3:49 AM
VIRGINIA
I think the k&n seal well. Nothing got by the k&n filter that is on my 084. I have the same setup that brewz has. Just bought an outerware for it to get rid on the foam k&n prefilter
mdavlee
Hillbilly grinder
3:49 AM
TN
Yeah sealed perfectly
If you to go back a page or so I posted a pic of the filter after cutting up an entire dead dusty tree.
Nothing got past.
The red foam pre filter is useless though
I probably seen it and didn't pay attention since I didn't have an 84 at the time.
CR500
3:49 AM
Western NY
A quick update after 3 hrs of run time. IMO it is doing a very good job at filtering... barely any fines are making it through. The outerwear cover is also collecting those little fines better. Also I peaked under the cover and the filter is about spotless. Maybe it directs air flow better?
RI Chevy
3:49 AM
earth
Did you happen to notice any improvement in the saw operation? Just curious.
CR500
3:49 AM
Western NY
Not really, I had to richen the carb a bit. Throttle response is still very crisp
RI Chevy
3:49 AM
earth
OK. Thank you. [emoji106]
