- 7:12 AM
- Jan 28, 2016
- Dike, Iowa
That saw will pull a 24" bar with 3/8 chain resprctably. Not many 50cc saws can make such claims, but I've seen it done.52E
I have a clutch cover on the way thanks to eBay.
Mark
I just sold one in good running condition with good compression and we must have different thoughts on what will pull a 24” bar because I’d never even had attempted it on the one I just sold. Had a 20 .325 and that was enoughThat saw will pull a 24" bar with 3/8 chain resprctably. Not many 50cc saws can make such claims, but I've seen it done.
If the saw needs full skip to pull it then it’s probably unpowered for the bar. Full and semi skip were designed for chip clearance in large wood not so you and put a 24” bar on a 50cc saw but like I said to each there own. Yes I can see the long bar for not bending over and I may work ok in that respect but soon as you burry the bar it’s going to be less than impressive so you go to skip to keep from dragging the saw down which will work but then cutting branches and small wood you need to use skip which I personally think sucks because it vibrates and is jumpy in small wood. So worst in both worlds for me I’ll stick with full comp on 65 cc plus saws with a 24-28”. Just personal choice just like I can’t stand wrap handles but some love them.There used to be quite a few 49sp Jonsereds in this area with 24" bars. The tree thinning crews used them so they wouldn't have to bend over quite as much. I bought one some years back at a second hand store and liked the 24" bar very much on that saw. I ran 3/8" pitch full skip and it handled it nicely.
If your cutting tensioned wood that may snap back a bit, the longer bar adds a measure of safety.I prefer to rest the saw with a shorter guide bar rather than hold it in my hands and cut with the long end
I’m sure I doAnyone here got an extra air filter knob for a 49SP laying around?
Wow, pics?Just snagged a new old stock 625,630,670 full wrap handle. Didn't think this type of thing existed. Any idea on the value of such a thing?
Wow, pics?
