Jonsereds 70E build
Frank bierce
4:39 AM
Oregon
Hmmm. I have a nice 70e that has been sitting because of a grenaded fan...when it grenaded, it also took out the coil wire. May have to get the flywheel with cool.... thanks!
awol
6:39 AM
Cabool, MO.
That's a good start, but if you want to change to that newer ignition you will still need a cylinder. The early ones don't have the coil mount on them. Also, if looking for a plastic fan, remember a 621 fan will work; they are a bit more common.
awol
6:39 AM
Cabool, MO.
What percent of the ring leaves it Allen?
About three fourths or a bit more.
I have the squish cut and after careful measuring it appears no part of the ring will leave the plating. I took it as far as it will go before it freeports under the piston.
The factory squish with the stock piston was .040; after cutting the squish it will be around .020 so the compression should be good. View attachment 41078 View attachment 41079
The 268 piston has longer skirts, so you can go a bit farther before freeporting. It also has wider skirts and a single ring gapped above the intake.
Heffalump
4:39 AM
NW Oregon
But the owner of this 70E really wants a 2-ring piston. I also have it on good authority that he loves real Jonsereds, likes Stihl a lot, fully appreciates old Macs and Homies, and has a general aversion to anything Husqy. ;)
Onan18
OPE Sponsor
7:39 AM
Georgia
Why, everyone knows single ring pistons have less drag, and Husqvarna parts make any other saw faster by default! ;)
Chainsaw Jim
Con Artist LLC
4:39 AM
Springfield Oregon
I had a chance to run this thing some more yesterday and it's going back under the grinder. The considerable amount of distance the ports needed raised to compensate for the taller piston has it right about at stock form if it were built that way from the factory. I didn't want to take too much the first time around, but now I know that it needs a bit more.
