BonScott46
- 9:57 AM
- Jul 20, 2016
- Sweden
Hi guys, bought a like new 2153 off Swedish Ebay. The guy wanted to send it to me with the bar and chain on but I told him it needed to be removed for shipping. I received the saw and the clutch cover was half on with the chianbreak engaged. Everything looks ok but when I run it the clutch drum is rubbing on the break band causing the clutch drum to heat up and the saw to run hot. When I run it with bar and chain the teeth on the clutch drum have jumped out of the slots in the worm gear and then pressed into the worm gear at another spot so when I removed the clutch the worm gear had to be pried off the clutch drum. At first I thought it was something I had messed up when I changed the rim sprocket over to 3/8 but it has happened twice and I am sure I reassembled it correctly after the first incident. I also noticed it is harder than it should be to get a bar and chain on. I don't really know where to start. The break band looks to be sitting in the clutch cover in the right spot and the clutch drum is not obviously bent or rubbing on the clutch... Any ideas?
