LAWN BOY
Pothole
- 10:27 AM
- Feb 27, 2024
- Merrill, WI
It lines up with the af holder and fuel line, so no.Is the carb upsidedown?
I can't tell by that picture
I'm not certain about the first thing, I could try.Does the throttle cable go into the lower portion of the carb plate? Which way does that plate rotate (from the position it is in the picture), clock wise for more throttle or counter clockwise?
Will do.Ok
Take a bigger pic of the whole thing...
Yeah, I have had some carbs I have taken apart and when I go to put it back together, it went back different than I remembered (I have started taking pictures of tear downs).I'm not certain about the first thing, I could try.
Counter clockwise.
I took the handle apart earlier and it became a disaster although at first the inside of the handle appeared to be functioning fine. I'll put it back together using that diagram. I also take pictures of projects, just not enough pictures lol.Yeah, I have had some carbs I have taken apart and when I go to put it back together, it went back different than I remembered (I have started taking pictures of tear downs).
I have not seen that saw before, but looking at the IPL, I am guessing the trigger pushes on the cable, if the cable was connected to the lower section, then it would push against the plate causing it to rotate counter-clockwise. That would be my guess. You might also take the handle apart and make sure the cable didn't slip out of its channel, if it has, then it might be giving you the slack you are wanting to take up.
Slightly different and I don't see an idle screw in that pic.Is your throttle cable ran like this ?
Looks like the idle screw was removed, there is the hole for it, but its not there.Slightly different and I don't see an idle screw in that pic.
Ya that's what I thought,Looks like the idle screw was removed, there is the hole for it, but its not there.
