John Deere 23
67L36Driver
5:52 PM
Slight detour related to our Deere refurb is replacing the side cover on our Wards 5.0" beater.
Broken at the bottom spike mount.
Can't have that!
67L36Driver
5:52 PM
Some day I should modify a wrench to make it easier to get the tube fitting off.
Rats!! Large amount of bar oil in the crankcase.[emoji37]. The oiler check must be blown.
The oil tank was holding pressure and I 'burped' it every time I ran him.
Fixed.
67L36Driver
5:52 PM
Got the Homie piston back from my friend and mocked it up with one ring in the top groove. Crown has .040"+ clearence.
Add flywheel and starter in the morning.
67L36Driver
5:52 PM
Preliminary compression check:
The geezer gets it to 60 psi but he stalls out.
Needs help holding it on the floor and pulling the rope, he does.
67L36Driver
5:52 PM
Put it together dry. I didn't want any oil to influence a comp reading.
psuiewalsh
Basement Bodging
6:52 PM
Nottingham,pa
Are they in? That would keep it low.
Sent from my XT1585 using Tapatalk
67L36Driver
5:52 PM
We got 90 psi. No oil, dry cylinder and one ring. Base gasket is .033".
Going to leave the piston crown alone.
67L36Driver
5:52 PM
Just discovered the flywheel side bearing is wider than the PTO side.
Torrington BH-1010.
Should have looked closer at the IPL.
Edit: Measured the length thru the case bore. We have enuff room for a 3/4" long bearing plus the 1/8" seal width.
We are going to upgrade the overhung load capacity.[emoji6]
Torrington BH-1012
67L36Driver
5:52 PM
Making parts green.
"Drys to the touch in three hours"
Yeah,.......................right.
Edit: Actually took twenty hours.
67L36Driver
5:52 PM
Put the rest of the gingerbread on him tomorrow. Skeeters be eating me up.
Put the manual oil pump w/lines on separate of the carb box/handle. Much easier.
67L36Driver
5:52 PM
Should have painted a test piece or two. Something to go by for fuel resistance.
I soooo much want to fire up this puppy.
Paint ended up just right. Not too shiny and slick.
It isn't a car fender.
