It's Stihl 044 time
markds2
1:41 AM
Nelson, New Zealand
Great thread Ed! Love the detail and your sense of humour. I've just had a tidy low hour 10mm 044 across the bench, was a nice runner but the front of the oil tank was stove in - so I had to split her to weld up the cracks. Rebuilt the bottom end while I was at it and replaced the clutch and drum, but didn't need to to touch the piston, rings or cylinder:
20230325_161740.jpg20230325_161751.jpg20230325_161759.jpg20230325_161805.jpg20230325_145314.jpg
Stihlalltheway
6:41 AM
Minnesota
When this things done and you’re bored and get a wild hair up your ass and wanna sell it please let me know, preferably after June-ish when I have money again mid season. I’ve been looking for a 044R 10mm for a while
Scotty Overkill
Serial Tree Killer
7:41 AM
central PA
Great thread! Hey any of you fine Gents happen to have the pto side of a 10mm case you'd part with? I found enough spare parts on the bench to build another slant fin, may as well try to do it before I sweep all these parts into a box til next winter.....
redline4
I'm huge in Japan
6:41 AM
Rosholt Wisconsin
This one is a 12mm.
maulhead
5:41 AM
Home
Me do.
redline4
I'm huge in Japan
6:41 AM
Rosholt Wisconsin
Jug, gasket, muffler. No heat shield as pointed out earlier on this particular saw.
I start the lower bolts, helps everything line up better. Tighten it down to the jug.
And bolt on the front cover.
I removed the bar studs. Again.
After some digging in my box O'chainsaw shìt, found a plate and used that one.
redline4
I'm huge in Japan
6:41 AM
Rosholt Wisconsin
Took the recoil off.
Unwind the rope.
Remove the spring, pawls, washer and pulley
Cut the rope.
Fish the new one through.
Tie a knot.
Call yourself a fuggin idjit because you didn't run it through the housing first.
Untie the knot.
Route it through the housing, pulley, tie the knot.
Reassemble..
redline4
I'm huge in Japan
6:41 AM
Rosholt Wisconsin
Make sure all the control lever positions operate.
Make engine noises because @Stump Shot says your supposed to
Slide on the filter base
Air filter.
It's a Cross performance filter. Has a nice foam edge to seal. And a Stihl filter wrap.
And install the filter cover.
redline4
I'm huge in Japan
6:41 AM
Rosholt Wisconsin
Some Ebay dogs and a standard chain catcher because the extra roller I thought I had wasn't there..
Bolt up the top handle.
Bar and chain..
It popped in 5 pulls, started in 2 more.
I'll try to actually cut something with it later today.
And...
