MG porting
- 12:49 AM
- Jun 28, 2018
- Wa
Exactly.Sounds like they're working around patents and are taking the scenic route to get to EPA compliance.
I wonder how much emissions were reduced from the 460 to 461. I'm thinking there may be a source in Germany that would know this?
The muffler opening is tiny. The transfers are canted in such a way that back pressure created in the muffler can back feed into the uppers. Plus the jet in the carb is small. The coil is also different. Ignition timing could be altered to help with fuel economy.
My point is just this.....delayed savaging is at best a gimmick. And.....it's a dirty way to purge the hydrocarbons.
Thanks for the info. If I'm understanding correctly, does l/h refer to liters/per hour fuel consumption and does g/kWh refer to emissions in grams per kWh of work?On the MS 460
Fuel consumption max. power/max torque 3,0 l/h, 516 g/kWh
absolute/specific 2,6 l/h, 516 g/kWh
On the MS 461
Fuel consumption on
max. power: 2,5 l/h, max. torque: 391 g/kWh,
absolute: 2,3 l/h, specific: 400 g/kWh
A German company flaunting an emissions test?
Get the *f-word out here.
Randy do you find more or less BD works better in the 461... and why? I know I’m poking the hornets nest asking that... I know there are different styles and opinions. That’s cool. I’m merely curious what Randy’s is.
Intake Duration?There are only a few saws I've encountered that are really sensitive to blowdown time. The 461 isn't really one of them. There's another part of the cycle that's as important as blowdown.....but few people rarely talk, or think about it. Do you know what part of the cycle I'm referring to?
Case Compression???
We just talked about that earlier today!Yeppers.
The time in degrees of crankshaft rotation from intake closing until transfers begin to open.
