Is this a 461 ?
Terrence Jefferson
6:07 PM
Salisbury NH
This ia my father in laws saw and he said it was near impossible to start without breaking the pull rope . Im pretty sure he is drop starting it cause i had no problems starting it but i did notice when i had it running that it was sloppy like it was missing mounts or something but just turns out that rhe case is broken and worn through. Is this common on this saw? Im not that familiar with stihl saws but i would like to repair this for him. 20200216_123404.jpg20200216_123359.jpg
Terrence Jefferson
6:07 PM
Salisbury NH
Yeah my father in law is a logger and if i remember correctly this saw had the fuel tank pulled from the motor when it was about a month old. Lol he is rough on equipment
BonScott46
12:07 AM
Sweden
046/460 cases and P/C are different than 461 cases and P/C along with plastics and maybe a few other things.
6:07 PM
When a 461 recoil is on a 460 only 3 of the 4 bolts will be used, but it will work.
AM tank holders and plastics are available, I would recommend OEM replacement vibration dampeners. I would also use the OEM control levers on the AM tank holder (if you get one of them).
I think I have some useable case halves if you need them, but I won't have time to dig them out till after the end of Tax Season (4/15).
I've seen more than one 460 get hard to start because the carb starts leaking fuel into the crank case causing some hydro lock. Likely the carb needs a rebuild.
