is STIHL the only one doing 4-mix and how does that make more power than 2-stroke?
lehman live edge slab
Live Action
2:14 AM
Mn
I doubt anyone wants to come out with chainsaws or more products using "4mix" type technology. When 4mixes were released Stihl claimed they HAD to develop the technology because it was going to be impossible to produce 2 strokes that met emission standards. The 4 mix machines are substantially heavier, more complicated and require more maintenance than comparable 2 strokes and Stihl lost significant market share when they were introduced.
Not a path most companies want to follow.
That’s ok that you don’t like them but lots do like them and actually like the torque they have on a weed trimmer or brush cutter. I have a pole saw with one and dad is still running a br 600 that he bought first year out. Should adjust valves on the br 600 but haven’t and starts/runs great still. If they lost a ton of market share they must have had all of it before because I don’t think they’re hurting in the blower/trimmer market.
EFSM
2:14 AM
Extreme southern IL
They first referred to such engines as C4, then as H4 (Hybrid 4). After the merger with Kioritz, such equipment rather disappeared from the market. What's left is their partially working website dedicated to this technology.
Actually, Echo just revived this with their new 5810 blowers. They are a real powerhouse compared to the 580, which they replace and were no slouch themselves.
el33t
9:14 AM
Poland
They did! MSRP is surprisingly low compared to 2-stroke models.
el33t
9:14 AM
Poland
Apparently Stihl isn’t the only one that thinks it’s still good
I wonder why they withdrew these products and are now coming back with them. Maybe it was about some intellectual property issues after the merger.
TheWizard
8:14 AM
Wales UK
I use my km130 with a pole saw, it cuts good lots of torque. But couldnt run a chain saw with a 4mix engine, it just wouldnt sound right, feel right or cut right. Put the pole saw against a 200t with same size bar and chain and you really cant compare it.
3:14 AM
southwest FL
They're not 4 Mix, but for what it's worth; Makita has/had real 4 stroke blowers and trimmers/power heads. No mix oil required.
I have one of the multi tool power heads myself, and it does just fine. May be picking up a 4 stroke blower soon as well.
They make absolutely no sense, but that's kind of the fun of them.
I think I may have read something about the Makita mm4 equipment not working right when held at certain angles, but I have no idea if it's true?
SOS Ridgerider
Muffler Modded Member
3:14 AM
Central CT
I've held mine upside down, and at every angle you can think of. Runs just fine.
Where it doesn't make any sense is for the professional using multiple different tools every day. Having all 2 stroke equipment, and a couple of other units that need their own gas can, is a recipe for disaster. Especially on a bigger crew. You're likely going to grab the wrong can at some point. Obviously by mistake, but that doesn't fix anything.
hacskaroly
2100 Fanclub Member
12:14 AM
Northern Idaho, Ehh
It happens all the time, especially if there is a can of 2 stroke and a can of regular gas on the job. Very high chance some 2 stroke will end up with straight gas in it and subsequently a scored piston at the least.
whitesnake
3:14 AM
NY
HokieJoe
Active OPE Member
3:14 AM
Virginia
Their higher power trimmers and blowers, here are a few benefits off of Stihl's website:
  • Familiar fuel mixture ratio (50:1)
  • Operates in all positions
  • Cleaner - reduced emissions
  • More power - high torque
  • Good acceleration - quick starts
  • Low fuel consumption
  • Favourable power-to-weight ratio
  • Compact construction - attractive design
  • Fewer vibrations
  • Low noise level
I have a FS 91R, works really good, though I wish I had gotten the version with the bike handles on it. Though if you are used to just 2 stroke engines and one of these 4-Mixes decides it doesn't want to start (won't fire at all), you need to check and make sure neither of the rods slipped off a valve.
I can attest to the lower fuel consumption, lower noise and torque. Lower vibration, maybe.
I love my KM131 with the pole saw and hedger attachments. I just bought the paddle wheels for snow removal. Works well, but I'm going to fabricobble some wheels for it.
HokieJoe
Active OPE Member
3:14 AM
Virginia
Yeah, I'm not sure 4-mix and chainsaws are a good match. As for the pole saw, you lose power through that long drive shaft, so no way it will keep up with a 200t. I still love the versatility of my Kombi though.
HokieJoe
Active OPE Member
3:14 AM
Virginia
Interesting, I didn't realize that about the 5810.
Recently, I considered the 5810 and BR 800. But after considerable reading and youtube vids I settled on the PB5910. It has similar displacement to the BR 800, but it's quite a bit stouter. Maybe higher 2t rpm's is important for blowers?
CORRECTION: Got my wires crossed. I bought the 9010T.
PissRev
3:14 AM
Ga
I know there are thousands of them out there and the owners like them. I have had only 1 in my garage and I would not want to own one.
Let's take a simple 2 stroke and triple the amount of moving parts. My thoughts are negative on it.
The one in my garage dropped a valve. Piston is shot, broken rod, cylinder is screwed and a bad crank bearing. The blower looks brand new but is 4 years old. Not much time on it.
I would rather have a smaller 2 stroke and a big tarp.
After the latest debacle with my BR 800 I will never ever own another four mix ever.
And don't forget about the plastic cam in the engine as well.
Squareground3691
3:14 AM
New England
What happened, I’ve had a BR700 for 8 years and BR 800 for 3 years, no issues so far, just adjusting valves about it,
PissRev
3:14 AM
Ga
Within the first two months of ownership, it went back to the shop multiple times and it had a new coil, a new carburetor, valves adjusted, new fuel filters, new fuel lines, and they still couldn't get it to run right. I didn't even get mad when someone stole it. 🤷🏻
I forgot that it also had a blown up recoil assembly.
Squareground3691
3:14 AM
New England
Dam , sorry to hear that,
Live Action
2:14 AM
Mn
So you got a lemon that happens in all brands. It sucks but the 800 seems nice and my 600 is the first version still runs well. I like the high torque low noise of the 4-mix.
