Intake block on a 3 cube?
5:28 PM
JB weld is cheaper and easier to get into place. Devcon is good but thicker and has to be pushed more where you want it to go.
CR888
7:28 AM
Does anyone think of the resosnant impacts when modding saw intakes. Is a tuned intake somthing worth worring about? The formulas and math are readily availible, size is a factor with a saw l know. A properly tuned intake can give a nice boost in power, but it seems with saws we all think within the square and rarely step outside.
Four Paws
Chrome won't get you home
3:28 PM
ID
Whatever you're doing there Josh, build two. Hint, hint. ;)
10-4
Reed valve block would be cool.
It would. It would add a good bit of volume to the case. I could see major value on a pipe saw where a guy could pump and make use of all that volume. Would have to be a custom reed block so it was small enough to be packaged on a saw.
ft. churchill
2:28 PM
Along the '49 trail in Nevada
Some two stroke bikes used a boost bottle as well. Would look cool next to a green wienie air filter.
Stihlbro
5:28 PM
Virginia
Does rigid mounting the carb to the cylinder have any negative effects on the carb itself due to vibration.
If done properly it should work with with no negative affects. That is what is so great on modifying with such work. There is no right or wrong way, you can either make it work and if it don't you redo, even if it means starting over.
Tuned intakes are possible, most try to fit modified improvements under factory covers. Fitting every thing in place and having it functions is the challenge. Unlike the bike world where you have the whole frame to mount, secure modifications.
