Intake block on a 3 cube?
Four Paws
Chrome won't get you home
7:16 PM
ID
I have a 48cc saw (Shindaiwa 488) with a tiny spigot mounted Walbro HDA. I'd like to run a larger carb, but feel the tiny intake boot and spigot will hinder the saw. I have debated welding a block on the jug.
Saw is in the 190-200 psi range - on gas.
I don't really have a goal with the saw. I'd like to be able to run it reliably in the woods. I'd consider turning it into a play thing and running alcohol...would need some guidance to get started down that route.
Four Paws
7:16 PM
ID
Worth my time? Anyone want to talk 3-cubes...any make or model...any fuel...woods port or full on muffler saws?
Stihlbro
9:16 PM
Virginia
I am all ears, willing to talk, show me some pictures of the saw with intake set up currently. May not have to weld. I need to see throttle linkage, choke and fuel line routing. Fuel.....alcohol with the work required eh, too many gas options. But hey, let's do this!!
psuiewalsh
Basement Bodging
9:16 PM
Nottingham,pa
Does the boot bolt to that cylinder? Maybe a bolt on intake?
Sent from my C771 using Tapatalk 2
Hedgerow
8:16 PM
Now we talkin...
Four Paws
7:16 PM
ID
I will get some pictures after work. The jug has a totally round intake tract and utilizes a boot similar to Stihl. The boot and intake tract is very small internally (about as big around as a pinky finger - 1/2" or so). The design of the saw facilitates a lot of room for modification and packaging under stock covers.
Thanks for your replies so far.
Hedgerow
8:16 PM
Sometimes an intake block is the only reasonable way to get the carb the saw is begging for, onto the jug.
The 488 is a solid platform to experiment with and I've not seen many threads on them.
Cut4fun
Redneck Chainsaw Repair
9:16 PM
Ohio
488 like yours?
Four Paws
7:16 PM
ID
488 like yours?
Yes, That is the intake boot and carb mounting bracket (white piece) from a 488. The metal ring slides into the end of the boot once it slides through the bracket. The carb bolts on into threaded brass inserts molded into the bracket.
Four Paws
7:16 PM
ID
Here are some pictures of the stock components. Feedback, thoughts, discussion, criticism all welcome!
IMG_20160106_3064.jpg IMG_20160106_49468.jpg IMG_20160106_1722.jpg IMG_20160106_24292.jpg IMG_20160106_338.jpg
Stihlbro
9:16 PM
Virginia
I'm studying the pictures, it will take me a few times. The area on top of the spigot to back of cylinder wall looks thin. But I foresee a tillotson hl or Walbro wj doable.
Four Paws
7:16 PM
ID
Thin-ish. I could TIG in some aluminum to fill it up. Then machine the area flat to weld the block on.
One thing I have noticed is that intake ports enter at different angles on different saws. Is there a science to this, or is it simply packaging?
Same goes for exhaust. These newer saws with cylinders tilted back seem to have the exhaust port exiting at a steep downward angle. Older saws, straight out perpendicular to the piston. Again, is this for packaging or power?
