IEL-Pioneer thread
Lee H
9:34 AM
cape cod ma.
If points are spotless then try a condenser. Seen it before
on other saws. Kinda trial and error at this point.
67L36Driver
11:34 AM
I'll pull it apart again and really check things close. At first I thought the points were just dirty or oily.
Basher
1:34 PM
Canada
Every mechanical part either wears out or has a lifespan. Many old condensers just dry up and stop storing electrical charge. I have yet to loose a coil from the RA on up through the Pioneer lineup but the ones used on the IEL saws self destruct, the covering cracks/splits all to heck on those ones.
  • Like
Reactions: DSS
Lee H
9:34 AM
cape cod ma.
I have to disagree on the Pioneer coils. I restored and rebuilt a few
last summer. Models 700, 750, 850, 1850, 1771 and all use the same
green coil. Everyone was all cracked and junk. I even bought a few
new ones from Rottmans and one was all cracked in the box.
67L36Driver
11:34 AM
It's the plastic they used in the fiftys.
Every Remington Logmaster I've had the coils were shot.
jacob j.
Only the weird
9:34 AM
Coastal Oregon
Somebody found a replacement coil for some of the bigger Pioneer one-man saws, I think it was Huck0155. It was a coil made for a single cylinder outboard motor from the late 60's/early 70's.
Wagnerwerks
12:34 PM
Pa
Is there a recipe for replacement of the farmsaw blue coils?
I have one here that means a lot to my brother in laws dad. It has already been converted to a Farmlite starter with the heavier starter.
Lee H
9:34 AM
cape cod ma.
Your correct Jacob, The coil is from an out board just not sure which one.
Just found it. Preffered parts J802, Ebay # 221730199876
Basher
1:34 PM
Canada
Wrong series of saws, the Ra and the Pioneer 600 series shared the same coils.
jacob j.
Only the weird
9:34 AM
Coastal Oregon
If you send me a pic of it, I probably have a replacement. I have several Farmsaw/Farmsaw II carcasses here.
Wagnerwerks
12:34 PM
Pa
Awesome. Thank JJ. I'll have to dig it out.
I was down to their farm this weekend and "gave" them a mildly ported 357xp to replace it. They're super people and I just found out the sentimental part... Figured I'd try and figure it out.
rocketnorton
9:34 AM
surrey, bc, can
I have the j802 wrote down here, along w/584477. omc p/n. have never tried it tho.
Nitehawk55
12:34 PM
Ontario
Pics of my P38 were too big , anyway I just got done doing the fuel hoses and carb today as it has been sitting most of 35 years and thankfully the owner dumped the gas out !
This was the 2nd of 2 P38's this fellows father bought together in 1981 and this was the back up saw which was hardly used .
Problem...NO SPARK !!....were do you start with these of just find a good module ?
Basher
1:34 PM
Canada
Does it have the blue Prestolite electronic module? If so its likely done for but we get some results sometimes by cooking them in the oven for an hour or so.
Nitehawk55
12:34 PM
Ontario
Yes it does , it's in the oven right now at 200 .
Shame , hardly used and won't fire . I guess that time is the enemy with electronics .
I did test the switch and wires for shorts and opens and tested good , the coil secondary showed it wasn't open either , had about 3k ohms if I read it correctly .
If the oven trick doesn't work I wonder how hard a good one of these are to find ?
