CountryBoy19
Active OPE Member
- 3:27 PM
- Mar 1, 2018
- Southern Indiana
I recently picked up a 1-owner minty 038 Mag II at an auction. I didn't need it but it was cheap enough I couldn't leave it go.
I did some searching and it seems the choke flap in the filter is problematic on these. Fortunately (or unfortunately) that isn't my issue. This saw sputters on the first pull and starts the 2nd pull EVERY time. Sadly, the flocking on the filter is disintegrating leaving the open mesh screen behind. I'm scared of the choke flap horror stories from other threads here and OEM filters don't appear to solve the problem. Should I roll the dice on one? OE? Aftermarket?
Is it possible to redo the flocking? I could remove and reflock if it's possible.
I have no desire to put a large filter and adapter/trumpet setup on this saw. I'm not sure I'm keeping it but if I do it will be a user saw (firewood, personal logging, loaner, etc) and a big filter isn't going to work with that.
