Huztl MS440 chain brake band tight
msmmce1
Active OPE Member
12:45 AM
Richmond va
Upon assembly the Farmertec clutch drum would barely fit in the case so I purchased an Oregon drum which was a little smaller and fit better but the inner ring of the brake band seems to drag very slightly, anyone know if this will cause a problem?
Thanks!
1990Husky262
12:45 AM
Massacusetts
mine was like that to. I replaced the drum with one from rotary (which i think is actually an archer)and fit better but still had slight drag. Im just gonna keep an eye on it and if need be will try a different brake band. You will know if it drags to much cause it most likely will discolor the band from the heat in the area thats rubbing
msmmce1
Active OPE Member
12:45 AM
Richmond va
Thank you!
