msmmce1
Active OPE Member
- 11:00 PM
- Jan 31, 2019
- Richmond va
Just built a Huztl MS180, everything went together well mostly. Top plastic is a little rough and the throttle rod is too long and the clutch engages at like 7000rpm, I will get an oem throttle rod and clutch. Started easy and seems to run pretty good. I noticed on the IPL that there is a heat shield on either side of the muffler but there was none in the kit, seems like it would need it! Anyone else run into this?
Thanks
Thanks
