Huztl MS180 muffler heat shield missing
msmmce1
Active OPE Member
3:26 AM
Richmond va
Just built a Huztl MS180, everything went together well mostly. Top plastic is a little rough and the throttle rod is too long and the clutch engages at like 7000rpm, I will get an oem throttle rod and clutch. Started easy and seems to run pretty good. I noticed on the IPL that there is a heat shield on either side of the muffler but there was none in the kit, seems like it would need it! Anyone else run into this?
Thanks
nohoff
professional flusher
9:26 AM
Germany
The heatshield on the right side is only for machines with a catalystic converter in the muffler.
Those are getting hotter and nead a heat shield on the lower side and clutch side.
