Husqvarna Tool..Worth getting .
Tor R
Novice, Leg model #2
2:21 PM
Mandal
I dont know what the hourly rate is in UK or US, but the hourly rate in Norway is 80£=95$.
Limited of what tools they need, carb clutch flywheel seal tools is probleby the only tools they use.
I get most of their waranty cased Huskies, for me who is collector I need a certain ammount crank tools.
Simondo
1:21 PM
UK
I do know that dealers are often over the £45.00 hr mark here but its "very variable" across the country. I am less than that so tend to pick up what the main dealers dont tackle..or ..the customer wont pay for . Can be a little tricky being at the bottom of the food chain ...hence ...needing to buy "Smart " tool wise .
Member
7:21 AM
Dealers in the States vary greatly by region and/or business model, as to their shop rates. I'm at half the cost of the other guy, charge only flat rate, not actual time and still do a professional job. So if buying the right tool, gets the job done right, that just puts a feather in my cap. Just like Simon says, I pick up work that the other guys can't or won't do. So it is a bit of perspective on what and when to buy more tools. When I order parts, I just order the tool that's needed too, slowly but surely I need to order them less and less, there really is a lot of them out there. There is also a bit of a time element to it as well, no doubt with the extra struggle of doing a job without the right tool(we've all done it) comes extra time to do that job as well, I for one can't pass that on to the next guy.
Simondo
1:21 PM
UK
I know the Thread name was "Husqvarna Tool" ..But.. as im nether a 1 make saw or tool kinda guy, here is one that... D D Dave... prompted me to get. Stihl genuine.. limiter cap tool.
Plenty of saws have them now and the dry wall screw is ok but this real fine left hand thread is a real neat job.
Simondo
1:21 PM
UK
1 tool fits all sometimes ..... Dolmar saw clutches on the 421(uk 420) 5105 and the 6100...at least. :thumbsup:
SawTroll
Information collector
2:21 PM
Troms, North Norway
This is from Husqvarna's workshop tool range.....its milled from 1 solid chunk and is real well finished.
Is it worth the £20.00 i paid ..sure is i think as iv been down the "socket cutting" rout before . Works till i get a real tight one and a air gun can over tax a cut socket. So spend a few £ 's once i figure. Used on a 560 xp.
Part no 575 25 14-01
Yup, I'm on my third one of those already.
I've got all the clutch pullers from Husky and they all hold up except the one for the 346/350 style clutches. But I also use that one way more than the others too.
You don't need any special tools (or a piston stop) to take those outboard clutches off the saw, a hammer and something to use as a drift is all you need. Then it is about one sharp blow with the hammer.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
7:21 AM
Provencal, Louisiana
I think u put undo pressure on the brake shoe springs when beating on the outside and reduce the tension on them
Simondo
1:21 PM
UK
Iv tried it Niko..i just dont have the knack as not had any successes. I much prefer the tool and a air wrench used without a piston stop (not a fan of them myself) ...pull start off (comes off for a clean anyhow) ..a short Berrrrrrrrrr on low power and that usually sorts it.
Tor R
2:21 PM
Mandal
The only type piston stop I use it the plastic ones to Husky, wonder if they cost 2.5£ each, worth every penny.
Another cheap tool that I can't be without is the airgap tool (0.3mm) # 502 51 34 02.
8:21 AM
i had to take off a clutch on a husky 385 and tried the hammer and punch trick and broke the clutch so i bought the tool and made it alot easier and less than the clutch i had to replace
Simondo
1:21 PM
UK
My new favorite tool from Husqvarna is their carburetor adjusting screw driver. Has a "pointer" built into the blue handle so when adjusting the carb you can see and track the adjustment, sounds kinda nit-picky, but sure makes it easier.
Not picky IMO...Have a few with a tab and use them in preference. The Stihl disk is a natty little job....
Nitroman
4:21 AM
Southwest Alaska
Here in Bethel, Alaska USA the local charge is $150.00 per hour.
Simondo
1:21 PM
UK
To answer your first question: I do not think it is a waste of money whenever I buy a tool. If you need it then you need to get it. You only need to break something once and it would have paid for itself.
I agree with you ...I was meaning to recommend the first tool to others as it happens but regardless of that , If a tool saves time and or, breakages then its cash well spent IMO
Nitroman
4:21 AM
Southwest Alaska
Sure! You know, there are going to be countless times you'll have to improvise a tool or a method to achieve a result, but as you initially stated if the company has done the R&D and made the tool.... :)
Simondo
1:21 PM
UK
Very true :)....Improv happens with me as i have a press and some other workshop gear that by the addition of flat and round stock enable some things to be done without pullers for example. A regularly used tool is the real time saver perhaps.
Simondo
1:21 PM
UK
What screw driver are you using with that Simon? As all the ones I have do not work with that gizmo. I've yet to use mine yet. :(
Il let you know as iv one on order after this thread prompted me to look at more tools !!:D
The standard stihl carb driver is V thin but im pinning my hopes on ether the Dolmar one or Husqvarna's old black sort. Time will tell on the DD and splined sort .
