HUSQVARNA HUSQVARNA THREAD
kfd518
9:11 AM
Central Texas
Show of hands for full wraps
For the 266/268/272.
Anybody interested in a am version?
Just trying to see how many are interested
Someone
Was talking about down the road if interest is strong
Maybe possibly having some made up
Personally I'm down for at least 2
I like the 288 pro safety diameter the best
Great grip feel and purchase
Hopefully below 100.00
I’d be in for one
chipper1
10:11 AM
Grand Rapids Mi
Absolution
10:11 AM
WV/NC
Who makes a 18" or 20" 372 mount bar in .404 or and .063 that I can convert.
PogoInTheWoods
10:11 AM
Ohio
A D009 (large Husky) mount pattern can be easily modified for Mac use so I would imagine it could go the other way around also..., with Mac having used .404 / .063 on many shorter bar applications. Should be no shortage of options there, though stud adapters may be required depending on what mounting slot width you're able to rustle up. D025 Stihl mount pattern may be an easier find in .404 / .063 and can also be adapted.
9:11 AM
I was looking at an Archer Plus D025 20" b/c awhile back on the bay https://www.ebay.com/itm/20-Guide-B...:3hMAAOSw32lYzt5O:sc:USPSPriority!66611!US!-1
And here's a 24"
https://www.ebay.com/itm/24-Guide-B...:DBMAAOSwWxNYztka:sc:USPSPriority!66611!US!-1
9:11 AM
Also an on old D023 bar after elongating the slot would work to.
chipper1
10:11 AM
Grand Rapids Mi
What are you trying to convert(sorry if I missed it), the tip to 3/8 so you can have an 063 setup.
You can run a 3003 stihl in 063 on there with an adapter on the studs.
If you get into the 28" or longer there are many options made by Oregon in 063, but it's a bit limited under 28 for a d009
9:11 AM
I reckon the man wants to run some .404 for cutting longevity in some dirty wood.
Absolution
10:11 AM
WV/NC
Yes you are right. I moved down south towards the coast. Literally everything has sand embedded in it.
9:11 AM
So what is he converting, to a D009.
Are there any of those hardnose bars left.
IDK I found a nos awhile back.
Have you tried different angles on 3/8s or semi chisel?
Absolution
10:11 AM
WV/NC
Nope, I've been running square grind. So I may have to drop back to a round for down here.
chipper1
10:11 AM
Grand Rapids Mi
So both of us are right, you want to convert a 404 to a 3/8 and you want to run 404?
Semi is slower, but you make it up in filing time.
Absolution
10:11 AM
WV/NC
No sir I would like a 404 bar. Whether Its a 404 from factory or I have to get a 063 bar and put a 404 nose on it.
