justoldsaws
From the land downunder
- 10:25 PM
- May 22, 2017
- Australia
Show of hands for full wraps
For the 266/268/272.
Anybody interested in a am version?
Just trying to see how many are interested
Someone
Was talking about down the road if interest is strong
Maybe possibly having some made up
Personally I'm down for at least 2
I like the 288 pro safety diameter the best
Great grip feel and purchase
Hopefully below 100.00
Like the 281.281 making some noodles for the chicken nest boxes, just love this saw.
View attachment 188697 View attachment 188698
Like the 281.
What kind of wood is that, looks a bit like locust, but red instead of yellowish inside.
Nice way to use the noodles though.
If you say it's very hard then it must be harder than the locust we have.Aussie Grey Box, very hard timber when its dry.
Who makes a 18" or 20" 372 mount bar in .404 or and .063 that I can convert.
A D009 (large Husky) mount pattern can be easily modified for Mac use so I would imagine it could go the other way around also..., with Mac having used .404 / .063 on many shorter bar applications. Should be no shortage of options there, though stud adapters may be required depending on what mounting slot width you're able to rustle up. D025 Stihl mount pattern may be an easier find in .404 / .063 and can also be adapted.
What are you trying to convert(sorry if I missed it), the tip to 3/8 so you can have an 063 setup.Who makes a 18" or 20" 372 mount bar in .404 or and .063 that I can convert.
You can run a 3003 stihl in 063 on there with an adapter on the studs.
If you get into the 28" or longer there are many options made by Oregon in 063, but it's a bit limited under 28 for a d009
So what is he converting, to a D009.I reckon the man wants to run some .404 for cutting longevity in some dirty wood.
IDK I found a nos awhile back.So what is he converting, to a D009.
Are there any of those hardnose bars left.
Have you tried different angles on 3/8s or semi chisel?Yes you are right. I moved down south towards the coast. Literally everything has sand embedded in it.
So both of us are right, you want to convert a 404 to a 3/8 and you want to run 404?Yes you are right. I moved down south towards the coast. Literally everything has sand embedded in it.
No sir I would like a 404 bar. Whether Its a 404 from factory or I have to get a 063 bar and put a 404 nose on it.So both of us are right, you want to convert a 404 to a 3/8 and you want to run 404?
Semi is slower, but you make it up in filing time.
