- 11:32 PM
- Oct 21, 2016
- Kansas
I bought it for pruning the wifes roses.
Good call lol.
162 or maybe an early 266? That handle looks to made of magnesium.
And did you see you one that jred bar.
I did not. Thank you for letting me know. What this saws value in running condition?
See if he will send you a close up pick of the id tag.What model is this. The guy wants $100 for it as is not running. Is this a good deal?![]()
I finally figured out my problem with that stinking 372. The ignition I was using was off an x-torq. Well for some reason it didn’t like it. I switched it to an standard one I had. Saw runs perfect now. It was about ready to go in the scrap heap.Funny you say this. View attachment 151759I went and took a peek at this 670 manual I just got.
Have you found the high idle setting for cold and warm starts?Husqvarna 181SE , cold start
Err, what?Have you found the high idle setting for cold and warm starts?
Lol...Yes the throttle lock for cold /warm starts.Err, what?
Can You translate that to Dolmar language, I am a foreigner in this thread?!
Are You referring to the throttle lock?
If not, what other setting is there?
OK, I know what we are talking about - my Sachs-Dolmar 105 & 108 have the manual throttle lock.Lol...Yes the throttle lock for cold /warm starts.
The 181 (unless it has had a carb change) has a manual throttle lock as well as the pull out choke. The choke works on its own so you have to pull the trigger ...and hold that little plastic nub on the top of the back handle as you let go of the trigger. The trigger and presents leaver should remain in a new position if you have engaged "Hi Idle" (throttle lock).
Yea the 109-110-111-115 usually have the sort with the square button on top of the back handle and do the same job.OK, I know what we are talking about - my Sachs-Dolmar 105 & 108 have the manual throttle lock.
The 181SE fires up OK without the high idle though, do I really have to set it?
I can try utilizing the high idle lock the next time I use her.![]()
