HUSQVARNA HUSQVARNA THREAD
redneckhillbilly
8:15 AM
NW MT
whats the best saw to port for a sleeper? is there any saw that makes an obsurd amount of power after porting that punches way above its cc size?
like for example could a 266 ported run with or outrun a stock 288?
9:15 AM
268XP
FergusonTO35
10:15 AM
Boonesborough, KY
If you are willing to consider another brand, my Echo CS-500P really woke up after Kris at S&S worked his magic on it.
jacktheripper
Papa Squat
8:15 AM
Wyoming
254xp in my opinion. Much lighter and nimbler than a 262, and can be gnarly when ported. I know that ported 562’s can run like ported 70cc saws too.
farminkarman
I like the red & black ones
9:15 AM
Neenah Wisconsin
My vote is the 365 special. Most people don't think anything of them. With a good port job + RWJ carb, they will rob a 90cc saw blind in wood up to 24". I don't have an actual 365sp, but rather a Jred 2165.
9:15 AM
True and true.
Jusgunn3
7:15 AM
California
Love mine that you did Greg, it’s a monster!
ZERO
Simple Life
3:15 PM
Woods & Mountains
Greg that would be the specialty of our good friend Steve @Stump Shot .
Maybe he can pull her out at the upcomming GTG.
Steve's 372OE build that he did for me, with extra goodies that I am very thankful of, put the local logging community on notice. And that is just with a boring 24" square cut and and old lazy magnificent seven.
EFSM
9:15 AM
Extreme southern IL
Husqvarna thread is not too active here but I will ask anyway...customer brought in a 240 that he only uses occasionally, as in once or twice a year. I went through it last year with fuel lines, fuel filter, carburetor kit and it worked fine for me but he says it dies after making a cut. He is using canned fuel and it looks and smells good.
I ran it until it was good and warm and tried snapping the throttle off after running WOT and sure enough it would die. I tried adjusting both H and L a bit leaner assuming it was too much fuel but it did not cure it completely.
I went through everything on the saw, compression is 150 PSI hot, crankcase holds pressure and vacuum just fine, carburetor holds 12 PSI, I can't get much more out of my squeeze bulb tester so I don't know where exactly it might pop off.
He needs it this weekend so I am sending it out the door but expect it will come back again. What else should I be looking for? FWIW, it always restarts in a pull or two if I put it in the fast idle position, reluctant to restart after dying with the throttle at idle.
I did look through the carburetor again, everything is clean, diaphragms are pliable, inlet screen is clean.
Mark
Did you ever get this saw sorted out? IIRC those carburetors have an accelerator plunger. When the oring is bad on it weird things happen.
Here for the Yum Yum Sauce
9:15 AM
I suspect in this endeavor that the race in question be a prime factor in what does what. It could prove to be a tough challenge with a long bar/large wood scenario. Otherwise in the short bar world there are piles of candidates that can do the trick, just depends on the race and if the big saw is geared up to compensate or not.
Main thing is that smaller saws can run at a much higher RPM, the trick is that the hunk of wood being cut will let it maintain that RPM in the cut, while pulling out full chips easily, if so, your "sleeper" saw may just take the day. :)
heimannm
9:15 AM
Dike, Iowa
@EFSM - I simply made some additional adjustments to the L adjustment and it seemed to work O.K. I also showed the owner how to use the high idle setting (choke on/off) to assist with hot restarts and he found the saw to be quite useable again.
Mark
10:15 AM
One of biggest pains in my back sides got me again .Husky 281 I've changed the carb ,changed all the anti vibes .the coil .Evidently whoever I bought the fuel hose from sent me the wrong one,too flippen short .I've got one ordered from the Duke of whom I've never gotten a bad part .That old Viking used to be a hot runner and it shall be again if I can keep my cool .-----mumble grumble ---
10:15 AM
Good ole Duke came through I got the fuel line today and it worked .Now I know there is a following for Husqvarna saws but why they made them like they did--a beech to work on .Partner certainly is not like that or any other brands for that matter . I battled that 281 for about an hour getting that fuel line installed .I'll give it a go after a short barley pop .Pause for the cause .Fact today I waged war on two of those saw ,the 281 and a 450 Rancher which for some reason won't start . That contraption has adjustable carb jets but they must be staked because I can't move them
jacktheripper
Papa Squat
8:15 AM
Wyoming
Everything on that saw is simple… I don’t know why you had such a hard time. Probably one of the most straightforward saws you could work on.
