Squareground3691
- 12:31 AM
- May 1, 2021
- New England
Sugar Creek Supply, hard to find originals , there as close as they come,Are they original or did someone remake them?
572?Did a Full Wrap for the 266XS , one more to go , View attachment 416593View attachment 416594View attachment 416595View attachment 416596
365/372 ,572?
Honestly about 45 minutes, start to finish, I did a couple before so I knew what to do ,Nice, was it a pita to modify?
Flip it over so we’z can see wacha did underneathDid a Full Wrap for the 266XS , one more to go , View attachment 416593View attachment 416594View attachment 416595View attachment 416596
You can try an insert but a replacement case is not outrageous, imoWondering if there is a go to fix for completely stripped and worn out brake mount holes like on this 350 below.
I was going to cut the self tapping thread off the original bolt and weld on a bolt large enough to engage with the current hole.
But thought I’d check with those that had been here before.
Just cut a slot into the first 2-3 threads and it will "self tap".Thought I’d dry something different for the stripped out mount.
Thread not really correct for self tapping, but tightened up ok.
