- 10:01 AM
- Jun 5, 2016
- Northwoods of Wisconsin
Have a sick stock 592xp in the shop fresh from the woods logging. It barely would start and would not stay running. Sounds like an air leak of some kind.
Decided to look at it physically prior to any more diagnostic testing and after removing the carburetor the culprit became apparent. The first clue was the primer bulb was misaligned in the hole by quite a bit. Second clue was the right side air filter adapter AV was off, allowing the entire setup to lean over. Third and final clue was the tear in the intake boot.
