Husqvarna 576 Repair Thread.
Onan18
OPE Sponsor
8:22 AM
Georgia
And one here.
Don't forget to plug the impulse line into the barb fitting in the cylinder.
Intake assembled onto the cylinder.
Set it all down as an assembly.
Drop the bolts back in and tighten them in a cross pattern.
Onan18
OPE Sponsor
8:22 AM
Georgia
Set the carb in the filter holder assembly, be sure the choke arm is in this slot.
And install the whole kit and caboodle back in the saw, being certain to get the choke back in the groove.
Run the screws back in and pop the A/Vs back into place.
Reinstall the kill wires and the dust boot.
Onan18
OPE Sponsor
8:22 AM
Georgia
Drop the spacer back on the crank.
Wind the worm gear back in.
Spin the clutch back on.
Grease up the bearing, set it in place...
And drop the clutch drum back on.
Onan18
OPE Sponsor
8:22 AM
Georgia
A little grease on the pivot points for the chain brake.
The brake flag, band, and linkage all have to set in together.
Set the spring in.
Carefully compress it into place, again, eye protection is a must.
Set the cam back in...
Onan18
OPE Sponsor
8:22 AM
Georgia
Reinstall the coil and connect all of the wires, a business card works well for setting the air gap.
Spark plug is the typical NGK BPMR7A common to most saws.
Recoil can go back on now.
And so can the bar pad plate.
Onan18
OPE Sponsor
8:22 AM
Georgia
New A/V mount.
Installed.
New fuel line is always a good idea.
Slide the cable through the dust bellows.
And route the lines through this cutout in the carb floor.
Onan18
OPE Sponsor
8:22 AM
Georgia
Slide the throttle cable through the groove.
Push up and lock it in place.
Pull back on the throttle arm.
Lay the wire in the guide.
Release the throttle arm and the cable will seat into place.
Member
7:22 AM
Hope this helps some people out, and again if I missed anything please feel free to fill in the blanks.
Might could have shown setting the inlet lever height as an important step, otherwise a wonderful job you did here Joe! Great work indeed. :)
