Husqvarna 564xp (g) fuel inject
legdelimber
5:26 PM
N.C.
Guys, I've never laid hands on the saw in question. I Probably never will.
But please allow me a moment to grumble off some of why I have my feelings about Proprietary parts.
Run into these things on Friday or Saturday repairs and it gets a bit more frustraing when you find out the only vendor for this group of countys is out of stock, or closed for the weekend or just closed up for good.. Campers and mobile home needs.
Spend a few years working across a range of repair work and you'll likely come to have that reflexive contempt for things that deviate from what are/were generally considered to be "industry norms".
Tecumseh and Roper building bastardized units for Sears/Craftsman.
Camper trailers having odd sized plumbing/drain lines.
Oddball electrical connectors, when there is room and environmental conditions that would be very well served by some catalog common Amphenol product or other standard item.
with apologies, I'll shut up here.
Tor R
Novice, Leg model #2
11:26 PM
Mandal
won't say much more about Proprietary crank bearings in this thread, I sound like the world's biggest fan boy.
A few years ago I measured the cranks.....
Old style:
254/262 - 147mm
357 - 142mm
Something in between:
346 - 133mm
242 - 127mm
Modern:
550/560 - 122mm
Now I don't know how the rest of you prefer a saw body, as an all-rounder for tree felling and limbing..
Tor R
11:26 PM
Mandal
Buying the 564xpg wasn't my original plan, I wanted an upgraded 562, which came with the mark II. Since I'm a bit slow, the 564 was released before I had time to buy the 562 mkII.
I rarely buy chainsaws, and the antivibration specs on the 564 are very promising, and my elbows are pretty bad.
That's the main reason I ordered it, and let others go, like the 254 and 262, 560.
Kept 242's/246’s, 346's, 357 and a 372.. Feels like the 564 fits in nicely with the ones I've kept.
Tor R
11:26 PM
Mandal
It's with me, unused so far, spike and wrap handle installed.
It was slimmer than I thought it would be, chain cover significantly better than the 560/562 had, and the wires in the handle are the best I've seen from Husqvarna.
One annoying thing, I assumed the outer spike would fit the inner one, it doesn't, it's exactly the same as the set.
Ketchup
Epoxy member
3:26 PM
Colorado
How is getting to that second bar nut with the wrap?
Funky sawman
Pony Power
2:26 PM
North idaho
Some girls faint over Michael Jackson
The 564 fervor is real. I acutually fainted on my first attempt to pre-order the 564. For just a moment, I pictured that electronic fuel injector pulsating and spraying a mist of fuel and chainsaw noises and spruce limbs scraping my nipples and I just hit the fkn ground.
Thanks for the laugh man!
bwalker
5:26 PM
Montana
Every time a new pro saw is released its hyped up. Often the early reports singing praises are BS. The Ms361 was an example. Early reports of its use suggested it was better than sliced bread. It turned out to be a complete turd in stock form. Same story with the MS362, Ms441, Husky 575, etc.
With that said its best to just wait a year or two and let the early buyers beta test the things.
HumBurner
2:26 PM
Humboldt
I'm all about reducing weight and keeping power, but there's a point where you're holding a little less weight a lot longer vs. adding a little weight and cutting faster while minimizing heat on the saw.
A 390 would've eaten through those bucking-cuts while the 564 took its time.
Outback
2:26 PM
Its the best thing ever and it can shave your nut hair with minimal rash. Every new saw causes this disease. Major manufacturers are not trying to blow their technological load in one shot. They need to plan for decades of slight improvements. It is going to be slightly better than a 562. That will not stop the need to blow their marketing load in your face like its the last saw to ever be made or that you'll ever need.
MG2186
4:26 PM
Summer,IA
It’s worked for Stihl, look at all the sheep and a 500I
mainer_in_ak
1:26 PM
Interior Alaska
With the bore diameter of a 70 cc saw and the stroke of a 50 cc saw, I dont think the weight savings on the 564 is all that impressive: 12.8 lbs. It still costs as much as a 70 cc saw.
They're marketing this as some sort of pinnacle achievement where this micro-penis-short-stroke architecture has made such a big difference in weight savings.
On the other end of the 60 cc bore/stroke ratio: an echo 590 weighs 13 lbs 5 oz. Its exactly the opposite: A bore diameter similar to a stihl ms 261 and a stroke similar to a husqvarna 181.
Maintenance Chief
5:26 PM
South Carolina
I know guys that rave about the torque of the 590
