As far as bearing failures go in the 562PXP(and 550XP) are concerned, bench analysis has attributed the retainer cage failures due to heat. In the pile of 562XP's I've gone through, this was the case every single time and has been well documented for years now, but I'll go through the scenario one more time here... it comes down to an operator unwilling to quit cutting with a dull chain heating up the bar and overtaxing the saw. The bar pad transfers the excess heat to the case which happens to have the bearing pocket right next to it. This then melts the cage enough to fall apart; all the bearing balls go to one side causing the seal to leak air until the top end seizes. Operators that keep a sharp chain do not have these types of failures.
As far as bearing pocket failures go, this too can be contributed to heat. I actually see way more 385/390XP saws with this failure than the 372XPXT and/or the OE for that matter. All of these saw's experience ZERO crankshaft breakage, thus eliminating the "flex" theory of a motorcycle engine. What is seen is too tight dull chains with burnt bars. And just how do we take a saw case apart, heat it up, the bearing will fall right out. Surely manufacturer specs have a part to play, we can see that the earliest versions had much more problems than that of later ones that came out.
So, in conclusion, we can say that if you want to keep your XP saw in good running order, run a properly tensioned and sharpened chain and you won't have these issues, don't want to quit cutting with that dull chain and you'll be visiting your saw shop real soon. No amount of oil ratio or secret blend will save you.
My conclusions come from actual case by case saws that I've repaired along the way. I have not seen a 564XP yet to even begin to comment on how it is built, I can only say that the subsequent 572XP and 592XP are faring much better having enjoyed a long R&D period prior to launching. The 564XP from what a Husqvarna rep has publicly said has also gone under such scrutiny, so, it at least has that going for it, as well as the under the hood sneak peaks we have seen, it looks nothing like a 562XP.
