preacher31
Active OPE Member
- 8:53 AM
- Feb 15, 2025
- North Carolina
Hi all,
FIrst, I'll tell you that I a complete newbie to chainsaw repair. I use chainsaws a lot, but have never disassembled and attempted to repair one until now. I have a 562XP that has run well until now. Over the last couple of weeks, I noticed that it was hard to start (by that I mean that it would turn over, but wouldn't start with many pulls) and once started, would cut off frequently at idle. Last weekend, the saw cut off during idle, so I went to lunch. When I came back and attempted to start it, it was clear that there was no compression. Could pull the starter with two fingers.
So, I decided this was a good time to learn. After reading a bit on this forum and a couple of others, I bought a compression tester. Could only get max 10psi with any number of pulls on the starter. Unfortunately, I did not leak test it before disassembling, so I don't have that information.
In the photos, I've included that crankcase, piston, and cylinder. Ignore the shiny, bad scoring on the top of the cylinder and at the exhaust port. That was my doing during disassembly. Part of my learning and lesson learned.
I run 50:1 fuel/oil mixture and you can see oil on the parts. I haven't run it without oil. You can see severe scoring on the piston on the exhaust side and, essentially, none on the intake side of the piston. I don't know enough to comment on the condition of the cylinder. However, I don't see a glaring reason for the sudden loss of compression. Maybe that's because I'm a newbie and one of you will see it immediately and can help me.
Appreciate any help you can offer.
Exhaust side scoring...
Intake side (before and after cleaning)
Crankcase area...
Cylinder...
Crankcase area...
Cylinder...
