Husqvarna 550xp pop up
WoodsliverDan
Mechanical Beaver Builder
12:02 AM
Michigan
Got around to making a case splitter tonight.
WoodsliverDan
12:02 AM
Michigan
Cont..
  • USER_SCOPED_TEMP_DATA_MSGR_PHOTO_FOR_UPLOAD_1546729449749.jpg_1546729451607.jpeg
WoodsliverDan
12:02 AM
Michigan
Ok, last night I got the new bearing in and case back together. If time allows this week I'll get another built for testing.
WoodsliverDan
12:02 AM
Michigan
I 86'd the trio brake mount on one of the saws. Need to do all of them now.
WoodsliverDan
12:02 AM
Michigan
Can anyone possibly explain to me how to disable the heated carb option on the XPG model? Or link a thread? Thanks.
Tor R
Novice, Leg model #2
6:02 AM
Mandal
Have never seen a service bulletin regarding the subject and it will be a little "if".
Back in time, when Husqvarna introduced heated carburetor, came on 346 XPG or was it 351G? - The heated carburetor circuit was coupled in parallel with the heated handles, just as they've done on most 5xx XPG's.
There were two generators in the 346/357 era, but, even on the normal XPG without a heated carburettor a generator with a split coupling was used, ie the generator was intended for both systems. This was going on for at least 4 years.
I have never measured any resistance differences on those 346 versions, true to say, I am 99% sure it is the same generator they used on 346/351/353/357/359 is the same generator they're using on 550/560/562 nowadays.
So out of what I think, that is IF my theory is correct, it's just to disable the circuit who head to the heathed carburettor elements.
WoodsliverDan
12:02 AM
Michigan
Ok, I am not electrically smart. Just unplugging it will suffice? Also, is there a schematic for hooking these up? I just took it apart 2 days ago and couldn't even follow it when I did it..
Tor R
6:02 AM
Mandal
The setup on XPG:
Grounding -> Generator -> front handle -> switch -> rear handle -> grounding.
Grounding -> Generator -> top carb heather -> airfilter heather -> grounding.
As you see, the only heather system you switch on/off is the handle heathers.
The carburettor heather is working permanent.
When you disable the carb heater circuit on 550 you dont plugin the wire who head from the carburettor to the front handle switch.
WoodsliverDan
12:02 AM
Michigan
The setup on XPG:
Ok, thank you for the info
XP_Slinger
They’re Just Saws
12:02 AM
Central NY
Simplest thing to do is unplug the carb heater and see if the handle heat still works. Will tell you if they’re wired in series or parallel. Is the plug accessible when the carb is installed? Never had a G model.
WoodsliverDan
12:02 AM
Michigan
Good point
WoodsliverDan
12:02 AM
Michigan
I'm still here, had time today before work to put tank and other parts back on saw. Just need to put recoil on, muffler, brake flag, clutch, etc.. this saw is stock with fresh ring, that I will use for baseline cuts.
WoodsliverDan
12:02 AM
Michigan
Ok, haven't been on much lately. Here's where I am at. I've got the case splitted on the 3rd 550xp, I am removing the broken stuffers. This saw I will reassemble with out the stuffers, and mod the same way as the one I modded. Same timing numbers, squish, etc. I will take rpm notes in the cut and timed cuts with same bar and chain. I am waiting on piston from dealer since the stuffer piece traveled up the transfer and wrecked the piston. I will have it running in due time.
WoodsliverDan
12:02 AM
Michigan
Well, I finally got the piston and cylinder kit from my buddy on Saturday. Sunday, my day off, I had to do u joints on the truck. Good time to be a setup machinist in the gear and sprocket industry! U joints took way longer than I planned due to 20 years of Michigan winters. Hope to get a second this week to get some stock timing numbers then machine the base and piston. Then I will have a 550xpg without stuffers to check against a equally modded 550xp with stuffers and a stock one.
