Husqvarna 550xp pop up
WoodsliverDan
Mechanical Beaver Builder
4:43 PM
Michigan
He can't explain in a thread or via pics what took him 40 years to learn. Also, no 2 guys will port a saw the same way so what works for others may not work for you.
I'm not questioning his background, I'm questioning his background on this saw.
WoodsliverDan
4:43 PM
Michigan
Who really comes into a 550xp thread and says they don't have to worry about over heating lol. They literally will overheat, and not start, stock. They even came out with a modified top cover, for wait for it, over heating! So I really am confused when he comes in here and says I dont have to worry about over heating, when I'm modifying this saw, in ways that can cause more heat.
tree monkey
3:43 PM
wi
Scott, please explain what else there is to do to a 550xp, cylinder/piston mod wise? I have not heard anything about ignition timing so I asked.
I'll wait.
your confusing an engine over heating with a carb that is being over heated.
but what the hell do I know about chainsaws.
I have nothing more to add
WoodsliverDan
4:43 PM
Michigan
Seriously? Over heating is over heating. Stratos run hot! Please tell me with all these tree monkey saws running around you know that stratos run hot, right?
4:43 PM
So please, make me out to be "dumb" on my own personal build thread, that I was hoping to do to help others, since I haven't seen a pop up for this saw. Maybe some of you "legends" should put your egos away.
Are you serious? Your thread went 2 days without a reply. I felt inclined to help you out with honest answers and you instantly doubted me. If you want help, don't be an Askhole
WoodsliverDan
4:43 PM
Michigan
I've thanked you. Really dude, wasn't talking to you.
Scott has gave ZERO input and has bashed my popup idea on fb.
WoodsliverDan
4:43 PM
Michigan
If anything, Scott, you should be offering help.
tree monkey
3:43 PM
wi
what was the stock trapped comp ratio? what is the trapped comp ratio now? are you anywhere near 10/1 trapped?
WoodsliverDan
4:43 PM
Michigan
Have you seen a stock 550xp over 150psi? I dont have the saw back together yet..
WoodsliverDan
4:43 PM
Michigan
no I never said what you are doing was wrong, I was trying to pass on some knowledge. sorry if you took it the wrong way
No, you were being cocky and didn't understand why I was doing it. Said taking .020" of the piston makes it weak, doesn't make the yields etc etc. You've tried it on a 550xp? I haven't, so that's what I'm doing.
