Husqvarna 550xp pop up
WoodsliverDan
Mechanical Beaver Builder
11:47 AM
Michigan
How are they doing with heat after timing advance? That's my main concern.
Nutball
10:47 AM
Mt. Juliet, TN
Why not add surface area to the fins, cuts into the edges? Open up some of the tight squeezes between the fins: around the ports and where unnecessary casting material is. A question I've had for a while: would polished fins cool better with faster flow to slip by closer to the surface or would the stock or a rougher finish be better for cycling fresh cool air from the channels between the fins?
WoodsliverDan
11:47 AM
Michigan
julian and I have done a lot of cylinder temp testing on both stock and ported saws.
I don't think the lite mods your doing is going to increase cylinder temps
'Lite' mods? Uhh ok. Compression, rpms and timing create heat. This saw is already known to overheat. Maybe stick to a saw you're more familiar with, I'm looking for real answers on this model. Thanks.
dieselfitter
10:47 AM
MN
How much weight did you remove from the piston?
dieselfitter
10:47 AM
MN
lol yeah Scott. sounds like you don't know what you are talking about. Maybe you should stfu.
tree monkey
10:47 AM
wi
lol, wow dude I don't know why your asking any questions, you seem to already know all the answers.
mortalitool
aka Nick Stoeckel
11:47 AM
Lexington, MN
Do you know who you're talking to?
Sent from my SM-G935P using Tapatalk
WoodsliverDan
11:47 AM
Michigan
Scott, please explain what else there is to do to a 550xp, cylinder/piston mod wise? I have not heard anything about ignition timing so I asked.
I'll wait.
11:47 AM
I'll wait.
He can't explain in a thread or via pics what took him 40 years to learn. Also, no 2 guys will port a saw the same way so what works for others may not work for you.
