floatingkiwi
- 5:18 PM
- Jun 24, 2024
- Taupo, NZ
Hi All
I have my 2012 450 E series (I) here that was new to me originally. It's been a part time saw with not a lot of running each year and kept well tuned and sharp etc by me, an engineer.
The beginning of a long story: Well, about 8 months ago it started doing what I can only describe as weird things in the cut after warming up (like literally 5-10 mins into cutting), which kept getting worse and worse. it would start to falter and stumble in the cut and would slightly idle up when on its side. Tuning wise (with my Tach) you could tune it perfectly really easily. as soon as you start cutting it would do these weird things. This thing has run like a sewing machine since I bought it - until now.
Crankcase leak right? sure, ok lets go down that road...
1) first visit to the doctor - supposedly pressure and vac checked, new fuel hose. Its all good mate!! NO. Brought it home, worse than ever.
2) second visit - carb kit installation. (charged me for a full kit and only installed the seals, but thats another story). Its all good mate!!. NOT EVEN CLOSE. Got it home with a terrible low speed bog - you couldn't touch the trigger for about 5 mins on startup. I pulled the carb to bits to find what he'd done - diaphram was damaged/bent, metering lever hadn't been checked, only seals had been done etc. AND he'd upped the idle to mask the bog.
3) third visit - (insisted on the better technician) Found supposed carb pump side seal leaking. new carb installed for free, full pressure and vac tested, tuned. Its all good mate!! Well, got it home and sure enough, as soon as I get it warm it starts doing the same thing.
4) I borrowed a new coil and installed that. FIXED!! Well, for about a day then starts doing the same thing again.....ARRGGGHHHHH.
So, I've now stripped the thing down fully and pulled the jug off the plug. It looks really good as it should for having done not much work. Crank side seals dont appear to have any issues but I'm throwing a kit at it anyway. the new zama carb has the larger 5mm 20 spline needles/jets which is a pain - no tool for that yet so I've used a bit of plastic tube.
Lots of oil inside the crankcase.
bit of carbony residue on top of piston, looks like it's been very rich.
bore is very good, tiny bit of random scoring but nothing of note.
Bearings are good and haven't spun in the housing.
no housing cracks or any evidence of invasion by oil or air.
Intake boot good, no cracks.
impulse line seems fine, good tight fit.
WHAT AM I MISSING????? The problem is it runs fine during tuning but then goes bad in the cut after a few mins.
