Husqvarna 372xp
10:08 PM
Just one of reds larger deflectors on top now Mike? None on the side?
Yes. Welded down. You can use stock screen that way. Or make the opening bigger and use a different screen.
10:08 PM
You could do that. I've never done them. Not sure how much They actually flow.
beaglebriar
The Peanut Gallery
10:08 PM
Warren Center, PA
I case matched the transfers raised the lowers by about half and widened the exhaust about a 1/4" on each side. Also matched the exhaust. I just cleaned up the intake but I think I might take it back apart and square it. My saw runs very strong. The one thing I didn't do that Bob suggests in his video is trim the intake side of the piston. I may try that as well.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
9:08 PM
Provencal, Louisiana
What were u thinkin of trimming the skirt to?
10:08 PM
I blend the lowers and case match them. Widen the exhaust a little bit depending on how much its raised. You can lower the intake floor of you don't plan on machine work.
Keith Gandy
9:08 PM
Is machine work necessary? With a gasket delete how low will the ex. Fall? How much psi with a gasket delete
