husqvarna 372xp x torq carb issues
brad ruch
3:09 AM
michigan
Here's my tag
RIDE-RED 350r
3:09 AM
Blossvale NY
Sounds like you got it pretty close. Follow Spike60's advice, he knows these saws better than almost anyone.
Thanks for fixing the recoil handle, my OCD was starting to twitch ;)
RIDE-RED 350r
3:09 AM
Blossvale NY
Lots of good stuff there on Walt's channel for sure! I really enjoyed the series on the 365/372/372XT and the Johnny-Red counterparts. Lots of valuable info there.
brad ruch
3:09 AM
michigan
I know i still watch them over and over.i gotta give him call sometime.i know he was on vacation.
Spike60
3:09 AM
Ulster County, NY
Sounds good enough that you don't need to replace the coil. But your saw is about 5 weeks before they made that switch. And supposedly the newer carb can only be combined with a digital ignition system.
I'd say it's running good enough as is; and the coil option would be out there if you need it in the future.
The part number for the newest coil is 588 937 403. This one actually comes with the boot already installed, so that extra step is eliminated.
brad ruch
3:09 AM
michigan
Sounds good.thanks
XP_Slinger
They’re Just Saws
3:09 AM
Central NY
My XT is a 13' model and I'm still running the unlimited coil I got from you at walts. Do you think the limited digital advance coil will run better than the black coil? I'm also running a 75cc top end on mine now though:D
Spike60
3:09 AM
Ulster County, NY
No, leave the unlimited coil in there. Especially with the XPW top end.
Keep in mind that coils for the XT are rev limited to 13,300. And I bet you're tuned a little past that, huh? ;)
XP_Slinger
They’re Just Saws
3:09 AM
Central NY
The limit is why I swapped the coil out. After porting my XT top end it really wanted to spin. And yeah I'm tuned a little beyond the limiter on the ported XPW set up:)
RIDE-RED 350r
3:09 AM
Blossvale NY
Remember it was a step or two before I stopped grinding on my XPW when it was slamming into the rev limiter making the tach go all wonky?? Limiter makes it a PITA to tune a ported saw.
