Husqvarna 356 BT carb help
Carhartt
5:38 PM
Central Pa
Looking for replacement carb for 356 BT back pack blower. it is a Zama carb but cant find the model online. Husky part # is 503 283 119. Can you make any other carb work on these blowers? I am fine with Walbro or aftermarket.
PS, what a pain in the azz to get that thing off and on. It doesn't have many miles on it. If anyone has any other opinions, it will idle but not high rpm. like its running real rich. If I put my hand over blower nozzle it will pick up rpms and die off when I remove my hand from blocking it off.
AVB
4:38 PM
Pluto
The 356 BT only revs to 6000 rpm with an idle speed of 2300 rpm.
Also reformat the part number to 503283119 then search. Also make sure your blower is between 2004-2010 as the newer unit uses a different carburetor.
Carhartt
5:38 PM
Central Pa
Ive found another part # that is also to work. 579462701 C1Q EL52.
