Husqvarna 350 experts please
bigfrank
11:36 PM
NorCal
I purchased a Husqvarna 350 that was non running. It has good spark and good compression and will start on prime. It was obvious that it had fuel problems right off. Changed the fuel line and filter as it was broke and the filter was off. Still no start. Pulled the carb and it appeared that someone had been in there. Gasket missing on the metering diaphragm, cheap plastic fuel hose that was kinked on the pulse line. Replaced the pulse hose. Pulled carb and ultrasonic cleaned it. Installed a new carb kit, set needle lever with Walbro tool. Still no start. It acts like it's not getting pulse. When I start it a couple of times on prime, then pull the fule line off, there is no fuel present at the carb/fuel like junction.
What is the best way to check to see if the saw is getting pulse? I have a vac tester. Thanks guys...
gurwald
8:36 AM
Sweden
Remove pulse line from carb, take spark plugg out for easier cranking och pull the cord and you should be able to feel the pulsing on the pulse line.
2:36 AM
350 gets its impulse through the intake boot. It’s probably sucking air through the plastic clamp and not getting enough pulse, or the boot can turn on the cylinder and break or kink off the rubber impulse port inside
beaglebriar
The Peanut Gallery
2:36 AM
Warren Center, PA
Plug the vac tester into the pulse port and try to pull vacuum. Should be easy enough to tell if it's plugged.
cuinrearview
Handy dood
2:36 AM
Dowling, MI
I got 359 to fix a while back that someone had thrown a China primer carb at. They plumbed it themselves too including a tee on the fuel return line to the impulse(which was disco'd at the intake) and the tank vent. I know not a lot of people know how it should go but take a second to make sure everything is in order.
