Husqvarna 288xp 181 crankcase repairs
Mattyo
Youtube speciawist
10:48 PM
Farmington, CT
Special thanks to @srcarr52 and @Moparmyway for the repairs over the years. Thanks to @drf256 as well for help and advice and of course @Glock37 for the powder work.
That said...im doing some welding! They aren't super pretty ....but I'm trying to revive some of these crankcases back to functional.
One common issue on these is the rash on the pto side that wrecks the positioning bushing that helps hold the 288xp clutch cover in alignment. Not a crucial part but a pet peeve of mine to see these not fixed.
Also....on the 181s....there is no hole .... so ya gotta make one
So....weld it up!
Then grind it and drill it...
After a little more grinding and powder this will be more solid than stock.
Another one....
hoskvarna
9:48 PM
Iowa
What process are you using to weld them
Sent from Hoskey hilltop
Mattyo
Youtube speciawist
10:48 PM
Farmington, CT
I have a tig... I think its set on 12a 100hz using 1/16" az92n blue demon rod.
Mattyo
Youtube speciawist
10:48 PM
Farmington, CT
Nope...I mean 12 amps. I have a tiny tungsten with a 5 cup... clean on 50% iirc.
No point in putting a tip on the tungsten. It balls up immediately with this stuff. Its super porous... but once you get some kind of a puddle you can add the filler and start laying a bead.
srcarr52
10:48 PM
Iowa City
Anything other than pure tungsten shouldn't ball up unless you are putting too much amperage through it.
10:48 PM
I'll keep fiddling with it... tx. ;)
Was really cool watching you repair those 288 cases the other day. Made them better than new.
thinair
7:48 PM
B.C Canada
Depending on the balance, but I prefer 2% lanth or CK LaYZr for holding shape on low balance high cleaning weld jobs.
