Husqvarna 2100 thread
Frank bierce
4:25 AM
Onan18
OPE Sponsor
7:25 AM
Georgia
Redfin
Meh...
7:25 AM
Central Pa
Guys, I'm going to try to repair a brake and for a 2101 by building a new band and attaching it to the old band rod. If I can get it to work I would be willing to build a few more in exchange for certain parts I'm missing
What are you in search of?
flying pig
5:25 AM
Grande Prairie, Alberta
The bent style 2101 brake handle and linkage is what I really want to find, and I also need a decent cylinder cover and filter cover. The 2101 I just got is in pretty nice clean shape and I'd like to complete it properly. It runs really good after I fixed the couple little problems it had.
flying pig
5:25 AM
Does anyone have the measurements off of a velocity stack for a 2100? Also do any of you guys have a part number for a K&N or Uni filter for a v stack conversion?
Drptrch
Coastal Fartknocker
7:25 AM
Petaluma, California
1.75"
.75" on mine that was on saw with a weenie filter
flying pig
5:25 AM
IMG_1700.JPG IMG_1701.JPG IMG_1702.JPG I didn't quite go as small as yours. Found an uni filter on eBay that has a slight angle back, which should be good on the mill saw for keeping me from knocking the filter off with my hip. I set it up for a 2" filter. Doesn't look like it in the photo but I radiused the intake not too bad for no radius tool. I'm thinking that if the filter moves I may cut an oring groove in the outside and put a D ring in it so the mouth of the filter has something to 'lock' onto.
This was one of the sketchiest set ups I've ever done on my milling attachment for my lathe. Ha ha.
7:25 AM
I finally got around to measuring that thing and some pics . 1.75" OD ,.95 '" ID of the hole that fits on the carb . .8" high with a little flange on the bottom . 1.375 bolt hole spacing .clearance for M5 bolts .It is a K and N filter but I can't find a number .
7:25 AM
Now then this "air trumpet " deal .They claim it might be good for a 2 to 4 percent gain .Unless you resonance tune the intake tract which is a science all of it's own of which I know almost nothing about .You can Google it if you want .
Daserlon
5:25 AM
Montana
Look what i found!0601172045a.jpg 0601172045.jpg I took it to my dealer to i.d. it and its a brand new OEM mahle 2100 piston. It was in a plastic bag buried under some parts my friend bought. It had rings but they where all rusty.
flying pig
5:25 AM
Finally received my filter for the mill saw. You guys that run pod filters, do you oil them? Saw dust must be really tough to get out if you do. You'd think it would plug off and you can't shake it out too, but it would really stop the dust.
